Hi, Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Here is a tip that will help you with changing your dryer plug.
heatman101
SOURCE: installing a four prong plug
Hello, while the info provided by "backwoodsctr" is almost correct, I believe he forgot to mention that on Dryers (220 Volts AC), the outer connections inside the dryer are "hot" or live legs (black or black and red wires) of the circuit, while the center one is typically the neutral (white) wire.
The difference between a 3 prong plug and receptacle and a 4 pronged one is simply that the 4 prong plug and receptacle has a dedicated ground integrated into it, whereas the 3 prong plug is what's commonly referred to as an ungrounded circuit. There is no dedicated ground in a 3 prong plug and receptacle that makes a separate, grounded connection from the dryer to the receptacle to the electrical panel of the house.
Also, please look at either the back of the dryer for a basic wiring diagram, or look inside the access panel where the dryer cord is connected. There should be indications as to what each terminal is for, as I stated, typically the outer connections are the "hot" while the center one is typically the neutral. If you notice a strap running from one of the dryer's connection terminals to the cabinet/frame of the dryer, that is the neutral. The others are the hot terminals.
If you have any doubts, please consult a local appliance tech or electrician as 220 V-AC isn't something you want to take chances with.
I hope you find this Very Helpful and best regards!
