Maytag Atlantis MDE7400AY Electric Dryer
Problems with Maytag Atlantis MDE7400AY Electric Dryer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Maytag Atlantis MDE7400AY Electric Dryer RSS Feed
View More Results for Maytag Atlantis MDE7400AY Electric Dryer
Questions and Unsolved Support Problems
Unsolved Problems for Maytag Atlantis MDE7400AY Electric Dryer RSS Feed
Answer
I have a brand new dishwasher. it doesn't seem to dry as fully as my old one and there is... (More)
Answer
Everything appears to work except no heat is being produced by the dryer.
Answer
maytag neptune gas takes have to run two cycles to dry clothes
Answer
Dryer does not turn off when set to any heat setting. The heat appears to be the same temperature... (More)
Answer
Maytag Atlantis Dryer. Will not start when drying setting dial is pulled out (which is the way in... (More)
Answer
I have a Maytag (atlantis) dryer. It is making a loud pop and blowing the breaker as soon as a a... (More)
Find a Manual
Maytag Atlantis MDE7400AY Electric Dryer Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
How to change your dryer from 3 wire to a 4 wire power cord. (short and...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power... written by MNTECH
Washer and Dryer Repair manuals and Parts
Please rate a Fix Ya!!! Thanks jj505 For all Washers/Dryers/Parts http://laundry.manualsonline.com/ written by jj505
Possiable Manuel HELP OR ORDER PARTS LINK
Please rate a Fix Ya!!n Thanks jj505 http://www.repairclinic.com/Home.aspx written by jj505
SAVING TIME & MONEY $$$
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if... written by DRRXR
Dryer operates but will not heat.
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six... written by gregorymholt
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards). 3-Prong or 4-Prong ?... written by jsrock516
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Atlantis MDE7400AY Electric Dryer
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Find an Expert
Meet our 2957 Dryer Experts
emissionwiz
Rank: GuruGuru
Rating:  90%, 8125 votes
Solutions:  14846 (922 Votes in the last 30 days)
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
slosmogman
Rank: GuruGuru
Rating:  86%, 303 votes
Solutions:  1175 (533 Votes in the last 30 days)
Experience: ASE Smog Technician Advanced Engine Performance General Handyman
projdoc
#3: projdoc
Rank: GuruGuru
Rating:  94%, 610 votes
Solutions:  1205 (473 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
dmftrucker
Rank: GuruGuru
Washers & Dryers ExpertExpert
Rating:  87%, 412 votes
Solutions:  1582 (437 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
justaskjoe
Rank: GuruGuru
Rating:  85%, 2011 votes
Solutions:  3902 (362 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
avid101
#6: avid101 Expert Moderator
Rank: GuruGuru
Rating:  87%, 1158 votes
Solutions:  2486 (363 Votes in the last 30 days)
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
hunter19_46m
Rank: GuruGuru
Rating:  92%, 166 votes
Solutions:  767 (325 Votes in the last 30 days)
Experience: I have worked on many electric dryers in my working career. I am also mechanically inclined.
localwonder
Rank: GuruGuru
Rating:  92%, 2795 votes
Solutions:  4939 (320 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
57 varieties
Rank: GuruGuru
Rating:  88%, 525 votes
Solutions:  1495 (283 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
barkencoa
#10: barkencoa
Rank: GuruGuru
Rating:  89%, 1230 votes
Solutions:  1681 (270 Votes in the last 30 days)
Experience: I am a retired experienced domestic appliance engineer Washers-electric cookers-electric dryers
Find a Warranty
Specifications for Maytag Atlantis MDE7400AY Electric Dryer
Key Features
Power Source
Electric
Load Type
Front Loader
Dryer Type
Home Dryer
Other Features
Cycles
7 Cycles
Cool Down Feature
With Cool Down Feature
Quiet Mode
With Quiet Mode
Energy Efficient
Without Energy Efficient
Moisture-Sensor
With Moisture-Sensor
Dimensions
Overall Depth
28.25 in.
Overall Height
43.38 in.
Overall Width (Display)
27 in.
Warranty
Warranty
1 Year
Maytag Contact Information
Main support number1-800-688-9900
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
