Model 220kv-k
on the little display screen it has come up saying reg1 and on the main tv screen it say select a zone 1-6 it wont go past it and if a dvd is in the player it goes to main menu and on top of the main menu is
(player's region setting)
<1> : region
<2> : region
<3> : region
<4> : region
<5> : region
<6> : region
pick out any one of these!
help me please
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
You have to set the region code according to your country region. If you wish to get some details; visit the site linked here. http://electronicshelponline.blogspot.com/ Search the site by type in the the key phrase "region code" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
hey. the manual has its region codes. we have the same problem. my dvd player says re61 and i don't know how to key in the code... i tried to press the 4 number codes but doesn't work. arrgh. makes me wanna throw it!
the time is automatically set once you choose your time zone and if you observe daylight saving time, you must check that box..
go
to the main menu, then system option and click on the time zone tab,
then select your time zone and check off the little box for daylight
saving time.
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV. Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV. Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows: D5: 1080p / 720p / 1080i / 480p / 480i D4: 1080i / 720p / 480p / 480i D3: 1080i / 480p / 480i D2: 480p / 480i D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings. Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution. Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.* * The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed. If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type. Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings. Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings. The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
1. Display MAIN MENU. Press ACTION key on remote. 2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key. 3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET. 4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF. 5. Press ACTION key three times to return to normal screen.
You can download the manual from Panasonic here if you need a copy.
In order to receive the TV's Guide system, the cable should be connected directly to the TV instead of the cable box if you are still using it.
How do you have the cable box connected to the TV?
