20 Most Recent
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Questions & Answers
VOLUME STUCK
you use auxilry port in your tv as volume problem volume out from direct TV cable bos insert in tv auxilry port
5/17/2012 5:20:01 AM •
Panasonic...
Answered
on May 17, 2012
Need the remote code for this model tv
Hello
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote code for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note: Switch OFF and switch ON your TV with its
front panel power control switch [Main power control] each time before proceeding for an other code.
OK.
1/20/2011 2:27:08 PM •
Panasonic...
Answered
on Jan 20, 2011
What is the tv//dvd/vhs remote code for pv-m2799
Hello
Four digit universal remote code for tv/vcr/dvd combo is
0437
Direct Code Entry
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
12/9/2010 7:25:38 AM •
Panasonic...
Answered
on Dec 09, 2010
Can't exit hotel mode on Panasonic CT-2552HE
you will need the panasonic remote..
hold down the V/- button on the television. Then press the AV button 3 times on the Panasonic Remote. This will bring up the hidden menu for you.
hope this helps
Cheers
Little Dish Fitter.
9/17/2009 3:45:43 PM •
Panasonic...
Answered
on Sep 17, 2009
No sound from built-in DVD player on TV?
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
6/10/2009 8:32:28 PM •
Panasonic...
Answered
on Jun 10, 2009
