Question about Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo
Black square in center of screen - no "closed caption" solution
I was researching to find out what may be the problem and all suggestions indicate to reset the "closed caption" to off but all I can find on the menu is "caption on mute" which provides option of "no, CAP1 and CAP2" - what do I do to get rid of the big black square .... in very simple terms!
Posted by paschmidt69 on
Anonymous
    President:
  • 2,992 Answers
Here are the steps from the owner's manual:
1. Display MAIN MENU. Press ACTION key on remote.
2. Display SET UP TV screen. Use arrow keys to select TV icon and press SET key.
3. Display CAPTION screen. Use arrow keys to select CAPTION and press SET.
4. Select CAPTION MODE. Use arrow keys to select CAPTION MODE. Press SET to cycle through caption settings until it says OFF.
5. Press ACTION key three times to return to normal screen.
You can download the manual from Panasonic here if you need a copy.
Posted on Apr 03, 2009
2helpful
Polaroid HD TV 32" Black square in the center of the screen,
Is your closed caption selected? I saw the same problem with my friend's Sansui HDTV.
2answers
Toshiba 23HLV87 HDTV
Please try to unplug the TV from the wall outlet and then rest it for a while pulg it again and test. if still the issues remain then try to see the all the switch menu infront of the TV maybe lock or got errors.
melnavz
3helpful
We have a black square in the center of the screen. The picture shows on the perimiter and the square goes away temperarily when the volume button is pressed, but comes back. Any suggestions
it sounds like someone may have accidentally turned on the closed caption text box. So simply. turn off the closed caption and you sould be set!!!!
Larry
5helpful
Why do a black patch appears in the center of the tv
Go into your setup menu and turn off closed captioning. The black square is a box for the text.
1helpful
3answers
Black square image on screen
meknow is right I think. To turn off your closed captioning hopefully all you need to do is get into the setup menu. You didn't list what kind of TV you have so this is a generic solution. Go into menu and in a setup menu there will be a closed captioning way to select to turn the box off.
The reason sometimes you see it and sometimes you don't is because some programs have closed cationing and some don't.
And because you are only seeing a blank box and not closed captioning is because there are different closed captioning standards. CC1, CC2, etc.
So if you can find the menu item that allows you to turn off the closed captioning, it would be a good start to solving your problem.
Rich
2helpful
Tv has black square hole in center
You have the closed captioning turned on for a channel that doesn't support this feature. Go into the menu page for closed captioning and turn it off.
Tv Problems
Go into your customer menu to closed caption and turn off the "text" mode... What you're seeing is a text box from closed caption but unless you have that additional service it will just me a black square...
Bill
2helpful
2answers
Closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
5helpful
Black square in middle of screen about 25in X 25 in
If a black square appears on the screen and you can see the picture around the edges, it means that the closed captions are on and set to "TEXT". Go into the TV's menu, navigate to the closed captions page and set the captions to OFF.
2helpful
5answers
Black Square in center of screen
I was about to go buy a new tv. I'm blaming it on the cat, thanks!
Open Questions:
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
