I do not know what I did, but I get the sound from 2 sources simultaneously in the speakers.. Previously the sources could be on, but if I chose any of them, the sound would come from there only
It is unlikely that your TV can read your mind as to which source you want to chose. All sources are active simultaneously. Only switching to the chromecast location will chose it.
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Check the Audio configurations. From the start menu go to control panel and audio settings and check the out-put devices, as somtimed you need to select the inernal speakers manually if you have previously changed them to an exteral source. Click internal speaker and run the diagnosis. You should be able to hear a beeping sound.
I'm confused - 1. I know that a speaker does not need drivers to operate - they just need an amplified audio signal to produce sound. 2. An HDMI output has a digital video and audio signal to transfer from a source like a computer or DVD player to a destination, like a TV set or an AV system.
You might have a problem with your sound card in your computer. I think you're missing a AV component system in your set-up - like a physical receiver or AV hardware.
I just connected the front main speakers and sound well, but when i
connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any
surround mode from any source.
