20 Most Recent Denon DRA-395 Receiver Questions & Answers
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Denon DRA-395... | Answered on Jun 26, 2015
You most likely have shorted output transistors. This will cause the fuse to blow, and usually burns up a couple resistors as well.
Denon DRA-395... | Answered on Apr 25, 2013
Replace super capacitor in the front board (C712) with part # 598-EDLF473A5R5C .47F 5.5V form Mouser Electronics. I did. It worked.
Denon DRA-395... | Answered on Feb 17, 2012
This machine does not use a "battery" in the normal sense. There should be a capacitor in the 1 farad range that is being used similar to a battery. This will be a part about the size of a dime and about 1/4" thick. It will be soldered to the board. Many are either a bright blue or black. I will look up the service manual and try to get a better location description for you. The outside of the part will be marked either 5V or 6V and 1 farad or 1000 uFD.
Hope this helps,
Dan
Denon DRA-395... | Answered on Feb 08, 2012
Stick a fork in it if it acts that way with no speakers attached.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Denon DRA-395... | Answered on Apr 02, 2011
Denon DRA-395 Receiver Logo
38 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
denon dar 395 sparks
  • Audio Players & Recorders
