Are you trying to move the cursor with the trackpoint, a usb mouse, or the pen? Have you tried restarting your computer? Restarting would likely solve the problem. If you can't move the cursor to the start menu, you can open the start menu with the windows key, use the arrow keys to navigate to the power options. Use enter to select the power options and shut down or restart the computer. If this does not work, press and hold the power button for 5 or 10 seconds to force the computer to shut down.
What happened before this occurred? Did you install any programs or updates recently, or change any settings on your computer?
When your cursor is moving, while you don't touch your mose, check if the underside is completely clean. And with a wireless mouse, please put your phone somewhere else, not to close to the computer. Then let us know if it helps.
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Click on windows explorer and find the file you want to move, once it is on the right hand side of the screen you can move the curser over the file name and hold down the left mouse button and move the mouse over to the file in the RIGHT side of the screen to the folder you want to drop the first file into and don't let go of the left mouse button untill you get to the file and wahh lahh!
I assume a reboot didn't help? I also assume you have checked the connectors? If you have PS/2 type devices DO NOT connect or disconnect while the computer is turned on.
PS/2 are round connectors and are usually green or purple.
Open the configuration panel (Classic view). Click on the mouse icon. Open the Cursor Options tab. Put a mark in the CheckboxHide Cursor during typing. You can also chek the box Show mouse cursor when I press thye CTRL key. You can also reduce the speed of the movement of the cursor. All these options are on the same TAB.
I?ve had a couple of Dells laptops do this and without fail the cause was flaky touchpad/mouse drivers. I would suggest going to the Acer website downloading the latest drivers for your mouse. If that fails try removing the driver and running with the Windows default drivers, that what I?ve been doing successfully on my company laptops for several years now.
Acer driver download page, the web site is really slow so be prepared for a long wait.
The closest match was the C300 so I?m assuming these are generic drivers for the 300 series. Use the pull down menus and select the following:
-Select Product Line = Notebook
-To the right of that select TravelMate C300 (way at the bottom)
-Make sure English is selected and click on the search button. Once the drivers page opens go down towards the bottom and load for TM C300 touchpad drivers
Let us know if you have any other questions and please don?t forget to rate this posting.
