Toshiba Portege M400 PPM40U01000E Tablet PC Logo
Question about Toshiba Portege M400 PPM40U01000E Tablet PC
Touchscreen/pen not working for Toshiba Protege M400
I had to clean out the whole hard drive and then reload all the drivers (becuase of a virus).
But now I cant seem to find the driver which makes the touchscreen work for Windows XP. Can anyone help?
Posted by avibenmosheh on
Anonymous
    New Friend:
Touch screen pan tablet window xp driver free download
Posted on Aug 12, 2011
Anonymous
    Scholar:
  • 59 Answers
Is your version of XP the one that came on the Restore Disks from Toshiba, or did you get a copy of XP and install it yourself.
Note that the digitizer on the M400 will not work unless you install Windows XP Tablet PC Edition. Even if you install XP and all the Toshiba drivers, it will still not work!
The only solutions are:
A. Use the original restore disk.
B. Contact Toshiba and buy a replacement disk. They are about $25 and take about ten business days to ship.
C. Buy a full version of Windows that supports Tablet PC's.
When I bought my M400 which I am writing this on, it had basic Windows XP on it and the digitizer would not work. In the end I installed Windows 7 Ultimate to solve the problem.
G-Luck. Fell free to message me if you have any problems.
Posted on Apr 17, 2010
Anonymous
    Sergeant:
  • 193 Answers
All available drivers for the m400 series can be found here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
click on downloads, then select your exact model
Posted on Aug 18, 2009
I have a m400 toshiba laptop and the touchscreen is not working what should i do help plz
Hi ,
if you have the operating system the computer came with , you need to put it in your cdrom or dvd player and open the disk to see all the files and folders , ther is where you should find a driver folder , open that up and look for your touchscreen driver and reload the driver , if this doesnt work let me know so i can advise further ..............................Goodluck Roy
I have install win 7 on portege m400 , but pen not working! Please help me!
Go to the Toshiba Mobile support web site for you exact model. Select Drivers download. Select Windows 7 32bits or 64 bit and download the latest versions of all that relate to the Tablet module, and that includes the Wacom driver.
If you Windows is genuine you can uninstall all the Wacom drivers then execute the Check new hardware wizard ( of Hardware changes) or even Windows Update
1helpful
2answers
Keyboard on toshiba protege m400 not working
hi this could be several reasons for not working firstly it could have been liquid damaged /spillage etc check keys are they sticking when pressed if so you will need to remove panel and remove keypad and clean the unit iff this fails check lead at base of keypad entering the board this might have come lose or even broken away .you might even try changing the keypad if all fails hope this helps you
Reload original XP pro back onto laptop Toshiba protege M400 with XP pro
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Installing windows xp on toshiba protege 500
When you power up press F2 or "del" to enter in bios .
then set first boot option to as your dvd drive so then put winxp disk then it boot with it.
1helpful
My Toshiba M400 did not read hard drive!
You need to activate the Raid diver. This can be done by slipping it into the XP install or adding the Raid Drivers at the time of installing the operating system. See Toshiba.com support pages for a copy of the Raid drivers
1helpful
Toshiba m400 builtin hard is offline
Did you look at the BIOS setting? Try hitting Esc then F1
Portege500 notebook drivers
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp# There you will find all your driver's.
2answers
3 KEYS OF KEY BOARD NOT WORKING AND S IS STUCK
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Top Toshiba Tablets & eReaders Experts
David Shaub
Steve
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
