Televison & Video Logo
Posted on Jul 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RCR312W problem I purchased that universal remote last year and it was working fine until one day, it didn't work anymore. When I press any buttons at all, the on/off button illuminates RED. I thought I pressed something wrong so recently, I bought the exact same remote. 2 weeks later, it does the EXACT same thing..worked fine and now on/off button illuminates red..what is going on here? what does the red light mean? Changing the battery doesn't work. Please help!
Sonny Berry
Level 3:
  • Master 8,617 Answers
  • Posted on Jul 09, 2008
Sonny Berry
Master
Level 3:
Answers
8617
Questions
Helped
1723455
Points
23750
I believe the remote is losing its program. Have you tried to reprogram the remote?
2helpful
CODE FOR RCR312W FOR MY APEX TV
Turn on the TV, Press and hold down the TV button while entering one of the four digit codes, if the ON/OFF turns off on the last digit entered, that's the correct code, if not, repeat steps, using a different code until it does..here are the codes,..1137,1141,1235.....hope this was helpful...
6helpful
2answers
Need to know "HOW TO" set up RCR312W
You have to hold the component button (TV) and enter the code from http://www.rca.com/codefinder. The SKU it asks for, on my RCR312W, was under the lid from the batteries. Hope it helps.
2helpful
Need a code for Hitachi Ultravision TV
hold power and tv button same time
until power buttton stays on then
slowly hit power button until tv turns off then hit stop button and tv will work with remote
Remote RCR312W for panosonic TV quit working what do I do
I found this at:
http://www.wikihow.com/Program-an-RCA-RCR312W-Remote
It is stated that it was obtained from the RCA Website - but I could not find anything other than a picture of the remote there.
1) Turn on the component (the tv, dvd, etc).
2) Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
3) Press the play button every five seconds until the component turns off. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
4) When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
5) If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
6) To save the new code, press and release the STOP button.
7) The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
91helpful
9answers
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
6helpful
8answers
Can't find code for my RCR312W to work on my Toshiba TV. I tried all different codes. Any suggestions?
Have you tried these codes?
Code 1000 for Toshiba TV Code 1048 for Toshiba TV Code 1072 for Toshiba TV Code 1105 for Toshiba TV Code 1109 for Toshiba TV Code 1118 for Toshiba TV Code 1160 for Toshiba TV Code 1190 for Toshiba TV Code 1241 for Toshiba TV
Rca universal remote not working
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
5answers
I bought your RCA universal remote that controls 4 devices. The code list does not list my Magnavox DVD/VCR combo (MWD2205). When I went to the website listed on the back of the remote...
hope this may help;
Regards,
VOTIT
69helpful
7answers
How do i program my remote
Hold button down for unit you want to program. (TV,DVD,VCR) Then hold down on off button at same time. On/off button will turn off then come back on. When this happens push the play button. Wait 10 seconds and then push again. Repeat until unit turns off. Once unit turns off push rewind button one at a time until unit turns back on then push the stop button.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
