Toshiba Satellite A505 Notebook Logo
A
Anonymous Posted on Dec 29, 2010
My mouse, and keypad both work, but my clickers do not. They DO WORK, but i have to click about 10 times for it to actually do anything. and sometimes the cursor will randomly press down and highlight things, and lock onto things all by itself. its driving me crazy, please help! ;( I have a Toshiba Satelite A505-S6965 !
Anonymous
Level 3:
President:
  • Master 1,812 Answers
  • Posted on Dec 29, 2010
Anonymous
Master
Level 3:
President:
Answers
1812
Questions
0
Helped
528219
Points
7608
Restore the system first.http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the problem is same change the mouse.
Follow the bellow link just click on.
After change the mouse if you will face in same look because virus affected.
http://www.fixya.com/support/t7439427-seems_put_anything_echo_ze
You will just download boo-table f-secure disk, http://www.askvg.com/download-free-bootable-rescue-cds-from-kaspersky-bitdefender-avira-f-secure-and-others/ and write cd ISO file and scan at boot time .
Hope it will help you.
I just purchased a Logitech 570 and it pairs with the computer, but the clickers doesn't work, even though the scroll ball works.
If you are using Windows 10 go to the control panel to the right upper and choose large icons.
The sections will all be separated, click on mouse and from there you should be able to set up the mouse clicks.
Good Luck
1helpful
Can't click on right
Hi!
That depends on the quality of the mouse that your using.
Cleaning/ opening the mouse will not work at all.
The quality of the mouse.
Mouse clicker buttons not working
In Control Panel there is a mouse section, you may have the clicking disabled. if you don't and it still isn't functioning then you have a bad touchpad and it will need to be replaced.
You can also test using a USB mouse to find out if you have clicking disabled.
My mouse keeps on skipping clicks, I don't know why. The wireless connection seems to be in order and everything else seems fine.
Did you try changing the batteries? If so, try unplugging the mouse receiver and plugging it back in. If that doesn't do anything, how long have you used the mouse? My mouse skips clicks because of my normal use over the years. Might just be the wear and tear to the little clicker button, but try changing batteries.
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Unable to right click to delete item
The clicker on the mouse has a plastic mount, if that breaks it stops registering the clicks. The plastic doesn't glue well and the part is not worth replacing. It's maybe a $10 mouse.
You can however reverse the buttons using the mouse option in the control panel of Windows and use the left mouse button instead to get by. At least until you get around to buying a new one. The enter key also often works in lieu of a right click when opening programs and Windows.
3helpful
3answers
Left click is broken
Actually, first you should try taking the mouse open and cleaning the sensor clicker thing or whole mouses insides, I had similar problem before, that fixed it for me.
Other option which I haven't tried and am not sure if works, you could try to move one of the side buttons that you don't use sensor to the place of the left mouse button. This I HIGHLY advice against tho since this might break down the mouse totally.
Then again if it comes down to not properly working mouse and you have to get new one versus broken mouse and you have to get new one, you have nothing to lose.
1helpful
Context menu continually pops up - mostly when left mouse button is clicked sometimes when keyboard is used. Context menu key doesn't work.
I think the mouse setting is set to left handed and the right clicker is the main clicker and the left is the context menu key. Knowing this, you should follow these steps.
1. Go to "Control Panel"
2. Click "Printers and Other Hardware"
3. Click "Mouse"
4. Go to the "Buttons" tab and switch the setting to right handed
4answers
Mouse will randomly double click or have to click several times to work
Please check whether there are any buttons on the side of the mouse you may be clicking these at the same time as you are single clicking.
You could also try going into Control Panel --> Mouse
Try Slowing down the double click speed
If that doesn't work try speeding it up
Another problem with a laser mouse is it jumps around the screen randomly if there is a pattern on your mouse mat or desk, or if either are too shiny or even glass as the laser reflects incorrectly on these type of surfaces.
3answers
Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
maybe it is full of dust on those buttons. Try cleaning it with a duster of mini-brush because it interrupts the function.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
