Sega Sonic Colors for Nintendo Wii Logo
Posted on Dec 29, 2010
My sonic colours game auto selects the wrong controller type on initiating the game so no control is possible - how do I get to select the correct controlle
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 29, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
242
Points
6
Make certain that you do not have any controllers plugged into the gamecube ports on the Wii console. We had DDR mats plugged into our console and the game would not recognize the wii controller.
  • tsaltmars365 Jan 01, 2011
    bobcattim706 - you're a star!! This was the problem - we did have a mat plugged in and on removing it, the problem is solved. many thanks.
1helpful
How to change the LED colour on The Orbis by Rotospa?
On the control unit select the 'up' arrow to cycle through the LED lighting options. Some units will only have one option (Blue) while other models will have a spectrum of colours to select from. Control unit diagram illustrated
here https://www.hottubhiremerseyside.co.uk/faqs/rotospa-hot-tub-controls-yyanwtjzu4olwmrgczqb3r2e-d-2.png
Oct 11, 2023 • Pool & Spa
tip
When I try to type the ampersand ( @ ) I get the quotation ( " ) sign instead
PROBLEM: Some keyboard characters type incorrectly and are swapped. Most notably the Ampersand - @ and the Quote sign - "
RESOLUTION: The wrong country selection for the keyboard layout has been selected. An ENGLISH - UK keyboard with an ENGLISH - USA keyboard type selected or the reverse.
Go to CONTROL PANEL, REGIONAL AND LANGUAGE settings and select the correct keyboard for your system's country of origin.
on Apr 08, 2010 • Computers & Internet
How do I find out why my computer has no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps you
D7000 in p/s/a/m all in b/w mode cannot find how to put back to colour
Your Picture Control is set to Monochrome.
To change the Picture Control, press the MENU button Select "Set Picture Control" from the Shooting menu, press cursor-right, use cursor-up/down to select the desired Picture Control, then press the OK button.
Full details are in the "Picture Controls" section of the manual (page 131 in my copy).
Playing Madden11 and cannot control the pkayers. Seems like in auto mode. How do I correct?
You have to make sure that you set your controller in the right mode either as player one or player two. It is possible that you have been making the mistake of not setting your controller as a player on either side and as a result, the game is detecting your controller as an inactive controller so it prepares a game between two sides of the CPU.
You can also make sure that your controller buttons(analog or digital) is working properly so it does not become a case of stuck controller buttons.
Another thing you might wan to watch out for is for the settings that are set to control the players to be in the right mode and selection that would suite your kind of play. For example, the game might have been set to move the players with the digital controls while you are trying to use the analog controls to move the player. This is because for almost all 2011 sport games that have been produced by EA have currently undergone controller review and changes.
The picture is not clear
go to the menu setting and select the picture setting and you can select the 3d colour management,base colour adjustment,active back light control,auto brightness sensor. thank you it might help you.
13helpful
2answers
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
Default Setting Change?
you need to set you initial copy screen up as auto colour select then go into copy settings and store them like that.
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Hi there
Check your DVD or Video player manual for regional setting, you may simply be set to the wrong region. Some players have a regional button on the remote control.
Regional settings allow DVD's or Videos to be played on the same player by simply selecting the correct regional setting.
If you are on the wrong regional setting, your picture will most likely appear in black and white.
Top Sega Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
