20 Most Recent
Dell Dimension 4100 (-JM0TB01) PC Desktop Questions & Answers
What is a tower of a computer
The tower is just another name for the case that contains all the internal parts of the PC. It's the box that you plug all of your equipment into (monitor, printer etc.)
SOUND CARD REPLACMENT
On a desktop it's easy to replace the sound card. Remove the power cord, open the case then purchase a PCI Sound card that will fit into one of the PCI Slots. You present sound card might be what is called an on board sound card (which is built into the motherboard). You won't touch the onboard sound card, you will simply add a pci sound card.
Nvrd32.sys could not be found
The file is an Nvidia Raid driver. You may have to copy the raid drivers to a floppy drive and install them via F6 during installation.
How do I find out why my computer has no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick ithope this helps you
Help me to connect 2 dell computers with cables
The easiest method of connecting any computers is to use a router which will also provide a DHCP server component to serve up local TCPIP addresses to each connected computer.To connect to the router you would need standard ethernet cables which are available widely and which would plug into the network port of the computer and the other end into the port on the router. You need one cable for each computer to router connection.If you have computers with WiFi / wireless capability, then you would need a wireless router and could then connect without the need for cables.Take a look at the
Practically Networked web site which has revies of various types of routers and also provides tutorials on networking and other related subjects which would help you.
Have a black screen with a white dash
If this is all you see when booting it can be may things. CPU,Motherboard, RAM issues. Are you hearing beeps? if so how many? This will usually tell you what the issue is.
No sound from dell desktop
You can download the audio and device drivers from Dell WEB site,the support download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows of the drivers for your Windows operating system. Click on thislink to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
I have a Dell Dimension 4100 and when I try to
there are two cables whith the monitor/lcd one for the power and the others goes to the computer
the message says that the cable is not attached to the computer properly take it out and refix it
When i turn on my computer it gives me a black
what was the last chage you did to the PC? Did you install any new hardware, specifically USB device?
- I would check the memory on this computer. Remove the memory from the slot and fix it back in and try.
- Are you able to access the bios settings? Since you are unable to boot, I would also check the harddisk to see if that is functioning properly.
I RECEIVED A DISK WITH WEDDING PICTURES FROM MY
If you load the CD and copy the files to a folder on your hard drive, say "Wedding pictures" for instance. If you then double click on a file within the folder when it has been copied, if you use Windows as your OS. it should automatically show the pictures within a programme called "Windows Media Player"
You should then be able to find your way around the files or pictures. Pictures on computers are in fact just files in jpg or tiff etc.
Hope this helps.
How to install command & conquer 3 without
You may need an ISO virtual disc mounting software. Try a free version of Power ISO or similar program. Start your searches from my initial suggestion and don't be lazy. Stay with it till you get what you need and you you should be good to go.
selk
When i turn on computer the dell logo comes uo and
Win 32 is the generic name for all
32 bit Windows
platforms and includes Windowes 95, Windows 98, Windows Me, Windows NT,
Windows 2000, Windows 2003 Server, Windows XP and Vista.
This is one of the Major program enable for your Windows to function.
So it would be best to perform a reinstall of OS
The monitor screen goes dark, then comes back with
could be with the monitor or video card/controller. first thing is to test another monitor if available and use a working video cable. if same thing happens, test if it is stable in safe mode. Restart the computer and press F8, then select Safe Mode. If display is stable in safe mode, it would be a video controller. Uninstall the existing driver, then download the latest one for your system through Dell support site.
