Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
Posted on Dec 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set wireless - Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Dec 28, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209572
Points
1609
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Cant acess the set up wizard
First you will need to check the wireless settings of the router. If you don't know the wireless settings of the router then you will need to open the set up page of the router and get the wireless settings. You will need wireless network name ( SSID ) , wireless channel, type of the wireless security and wireless network key or passphrase.
Click Here to know how to check the wireless settings of the router.
If you know the wireless settings of the router then you will need to open the set up page of the WET54G and put the same wireless settings on the wireless briidge.
To access the set up of WET54G Click Here
I have a wireless G,live in Italy but cannot ge successsful setup
First configure the wireless router with the SSID and WPA encryption etc and the configure the wireless card in the computer with the wireless router's settings. Please click on this link for information on how to secure the wireless router, configure the router's wireless settings and configure the wireless card in the computer with the router's wireless settings :-
http://www.fixya.com/support/r3559128-wireless_router_security
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
Click Here for step by step instructions
1helpful
I misplaced my cd to connect my other laptop to the wireless router, WRT54G, and I'm trying to get it through your site
If your router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
Click Here for more info
Won't recognise wireless router
It appears the wireless card in the computer hasn't been correctly configured with the wireless router's settings.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
3answers
I want to hook up my laptop wireless with the Actiontec GT704WG how do I do this- it is my only comouter
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
2helpful
2answers
How to set up the router? can only connect to the Internet when the laptop is connected directly through the router
The wireless router needs its wireless settings configured and also the wireless card in all the laptops needs to be configured with the router’s wireless settings so the laptops can communicate with the wireless router.
1helpful
How do i use my wireless internet card on my ps3 new version? do i need a usb cord?
Just configure the wireless setting in the PS3 with the wireless router's settings Eg. the wireless router's SSID and encryption etc.
If you don't remember the wireless router's settings then open IE browser and enter the router's IP configuration address and go to the wireless settings.
Use these settings and go into the PS3 wireless configuration and enter the router's wireless settings.
The PS3 will now connect to the wireless router.
4helpful
I cant connect my ipod touch to my linksys WRT160N router
hi! check first the wireless settings of your router, it may be set only to connect wireless n adpater, u have to set it on all wireless, b,g,n, if the settings is not set to all u will not able to use ur ipod touch to connect, I bliv ipod touch wireless adapter is wireless g. check also the wireless security settings if ssid is not broadcast, make it broadcast or if u dont like to broadcast it, just remember the ssid and try to check as well the wireless settings of ur ipod touch..
2answers
How do I install linksys router
Hi there, and welcome to FixYa
Connect the pc with a cable to any of the four LAN connections on the back of the router.
DO SET THE ADMIN password as the first thing you do.
goto -> administration -> management, fill out the router password and reenter it to confirm.
Give your network a name (SSID) so that you can find yours if there is more around you. Network name are called SSID, short for service set identifier
goto -> wireless -> basic wireless settingsWireless Network Mode : set to mixed,
Wireless Network Name (SSID), set a name well known to you, NOT your address :-)
now set the  Wireless Channel :  to any other than channel 6, which is the one everybody use. Too much electrical noise might interfere with your transmitting.
Now, go to Wireless -> Wireless connection, to set the Encryption security settings.
Set security mode to WEP,
Set the Transmit key to your choice, if you know that you wireless card has 4 keys as well, I would use key 4.
Set WEP encryption to: 128 bit 26 hex digits.
Go down to key 4, and find combination of numbers and the letters a, b, c, d, e or f.
(ex. 414243444546474849404a4b4c) = 26 hex digits.
Save settings.
Now, before you leave, WRITE DOWN your SSID, your password and key 4 with your settings, as you need to set your wireless card with the same settings.
Start -> settings -> network and right click your wireless connection and click properties.
At the top, choose Wireless network, find your network, (your SSID) choose properties and set these settings as you wrote down from the router.
Now, remove the cable and logon wireless.
/Teis
Do let me know how you are getting along.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
