Question about Belkin (F5D7231-4) Wireless Router
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
Posted by rmchugh718 on
Prashant M
  • 2,277 Answers
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
Click Here for step by step instructions
Posted on Dec 27, 2009
Add a password
The router's encryption (password) is configured in the router's wireless settings.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 10, 2012 | Belkin Basic Wireless Router
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
I have a home pc and have just purchased a new laptop, having connected both to belkin router i get internet fine on both machines, but cant play games on either or watch vids on utube with out them...
try resetting the router by holding down a botton that is located on the router...hold it at least 15 seconds then release,wait for 5 more minutes then try it out.
Oct 27, 2009 | Belkin Computers & Internet
I want to add another computer to my Belkin wireless router.
Purchase a wireless adapter for your apple laptop and connect to your wireless network using the same settings as the PC.
Jun 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Hi my friend has a belkin g802.11g router for his laptp and only 3 of the lights are on the etreme right isnt working his pc is telling him he has connection to the internet but its not letting him connect...
the router must be connected properly to the pc and set up to function properly first. Usually the pc is plugged into port 1 while the internet connection is plugged into the main "Green" labeled port which is spaced further away than the other 4 ports. If that's done properly then you have a few software issues depending on the ISP he is using. For instance, Road Runner doesn't really care what you use, however Yahoo DSL has issues that must be configured to make the modem communicate properly with the router. Does he see the wireless network with his laptop? Is he using 2 pc's, one hard wired to router and a laptop or just the laptop? If he's using just a laptop then you have a specific setup procedure that must be followed, contact the mfg of the modem, belkin's usually pretty good with walking you through the setup.
t
Nov 14, 2008 | Belkin Computers & Internet
Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 07, 2008 | Belkin (F5D5231-4) Router
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D7231-4) Wireless Router Logo
325 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
