Good day sir/madam
There are most likely 2 sources of such problems, the battery or the charger.
Test the battery on another device, but before you turn it on, charge it for about 2 hours on the device before powering on, if it turns on, then the battery is okay, but if it does not turn on the other device,then you have to replace the battery.
Test the charger on another device to see if it will charge it, if it charges, then the charger is okay, but if it does not, then the charger is bad and the solution is for you to replace it with a new one.
Other components to test is the charging port, to test the charging port, try a well tested charger and battery on the nuvi, if it does not seem to charge, then the charging port is bad and need to be replaced.
By the time you carry out these activities, you would have been able to detect the exact problem and solve it at the same time.
Hope this helps.
