Connect the charger to the camcorder. Plug the other end into the wall socket. Amuse yourself with some mindless task while the battery charges. Once charged, unplug the charger and the camcorder.
Something similar happened to me. I finally gave up on my wall charger and tried connecting my PDA to my computer and pressed reset button several times. I left it connected overnight and It was working by the next morning. My guess is that my battery was completely drained and my wall charger quit working.
unplug it from the comp if you havent already. does it have those sunken reset buttons? check the manual or online if you are not sure. if YES, reset the device and move on to the next step. If NO, you can either remove the battery (if possible) and try it back after a little while, or better, let it run out of charge and remove the battery then. By this time, please reboot the computer to make sure its fresh, to use layman language. Does it use a wall charger or has to charge on the comp? Does it have a regular USB 2.0 slot, cuz then you can use your phone charger or some other wall charger with the regular usb jack (male part). If no wall charger, I guess just re-plug it into the rebooted computer, and see if this helps it any. Sometimes my old Ipod 1st gen nano does this, and does not have a reset button or a way to remove the battery, so i just let the charge run out and the battery die, and when I charge it again, it works just fine. tell me how this works.
if you don't see a light on the charger lite up its the charger, or the internal batteries are no longer excepting the charger. my first guess is the charger itself.
What I did when I got this error was to push the reset button on the bottom of the player itself... Mine rebooted and took a charge from the computer. Hope this all works for you.
Well it is both. It should only ever say bootloader when it is plugged in to a PST machine and getting the software updated. I would say that it the hardware is causing the poor battery life or a combo of the battery and the phone.
Plug came off the wall?
What do you mean by this, the plug to what exactly the charger?
How is the charger camera battery set up?
Where is the red light on the charger?
More detail please
