Linksys WRH54G Wireless Router Logo
Posted on Dec 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to open my nat type it is moderate right now
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Dec 22, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209573
Points
1609
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
I went on a trip and connected to a network with a moderate NAT type. When I got home I tried to connect back to my original network which is usually open and it didn't switch back to open. I connect using...
var YAHOO = {'Shortcuts' : {}}; if (typeof YAHOO == "undefined") { var YAHOO = {}; } YAHOO.Shortcuts = YAHOO.Shortcuts '' {}; YAHOO.Shortcuts.hasSensitiveText = false; YAHOO.Shortcuts.sensitivityType = []; YAHOO.Shortcuts.doUlt = false; YAHOO.Shortcuts.location = "us"; YAHOO.Shortcuts.document_id = 0; YAHOO.Shortcuts.document_type = ""; YAHOO.Shortcuts.document_title = ""; YAHOO.Shortcuts.document_publish_date = ""; YAHOO.Shortcuts.document_author = "[email protected]"; YAHOO.Shortcuts.document_url = ""; YAHOO.Shortcuts.document_tags = ""; YAHOO.Shortcuts.document_language = "english"; YAHOO.Shortcuts.version = "2.10.0"; YAHOO.Shortcuts.annotationSet = { "lw_1299607050_0": { "text": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "extended": 0, "startchar": 286, "endchar": 363, "start": 286, "end": 363, "extendedFrom": "", "predictedCategory": "", "predictionProbability": "0", "weight": 1, "capAbtScore": 0, "abtScore": 0, "csScore": 0, "prismaScore": 0, "spectrumResolutionScore": 0, "conceptScore": 0, "type": ["shortcuts:/us/instance/identifier/hyperlink/http"], "category": ["IDENTIFIER"], "wikiId": "", "relatedWikiIds": [], "relatedEntities": [], "showOnClick": [], "context": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "metaData": { "linkHref": "http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360", "linkProtocol": "http", "linkRel": "nofollow", "linkTarget": "_blank", "visible": "true" } } }; YAHOO.Shortcuts.annotationSetID = "1eac068650c8d27415163f15165866e5"; http://www.xbox360forum.com/xbox-forum/threads/51908-How-To-Open-NAT.-xbox-360
This is what I did.
I went on a trip and brought my console and connecetd to a network with a moderate NAT type. When I tried to connect to my original network which usually has an open NAT type it would not switch to open...
Thats odd I know I have a moderate because I'm using a wireless 360 network adapter and my brother has open as he uses a ethernet cable. Also maybe if your bro unhooks his maybe yours will be open and his will go to moderate.
2answers
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
I need to make my Nat type open instead of moderate. How do I do that?
I just opened my NAT type to play xbox live...using a SURFboard Motorola.
And this site helped me alot:
http://webcache.googleusercontent.com/search?q=cache:d_5pu90czsoJ:news.softpedia.com/news/Guide-to-Opening-NAT-Xbox-360-71775.shtml+nat+type+xbox+360+open&cd=2&hl=en&ct=clnk&gl=ca
but watch this video first, cause it will help out allot too:
http://www.youtube.com/watch?v=gb9kafn8Ebs
With these guides, and bit of web reading from other peoples FAQ's.. I did it.
The guide you need will depend on what modem/router you have.
Good Luck
How do i open my NAT type? i have moderate NAT type and i wish to open it, how to do so?
login to the router and enable uPnP - it should be on the security screen. if you don't have uPnP as an option you will need to use port forwarding rules. These depend on the application reporting the moderate NAT.
Let me know if you need further details on how to get into the router.
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Xbox needs NAT settings to be ''open'' not ''moderate'' How do I do this?
You need to go into your routers configuration page and Change the NAT, Network Address Translation, to "OPEN" or in other words, ALL traffic can pass through, as opposed to the "Moderate" or Allowing ONLY certain sorts of traffic to pass through to your PC. You need to look in your manual as to how to do this. basically you type the "Address" of the "Router" into the address bar of a browser, and login with login & password, then go to the NAT section and change it there.
My nat type is moderate on my xbox360 and i have a laptop running off a zhone router i cant go to any ip address web page. it tells me cant connect to webpage. what are the steps to makeing my nat type...
Are you able to get into the router configuration somehow? You need to open ports on the router, for the xbox to not be moderate. Let me know the model router you have. If you like I could connect in to your computer remotely and give you a hand with it.
Halo 3
make sure the security settings on router is WEP-Personal. I don't know what you have for internet but Dial-up, DSL, and satellite internet will not get NAT 1.
NAT from moderate to open (xbox 360)
You need to open ports for that game on your router. Nat can't be disabled, make sure the correct ports are properly forwarded on your router. Contact the game manufacturer for the port listing.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
