Video Game Consoles & Games Logo
Posted on Jan 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
242
Points
0
Anonymous
Level 2:
New Friend:
  • Expert 110 Answers
  • Posted on Jan 19, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
110
Questions
Helped
8471
Points
175
You should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Im playing call of duty and cannot get onto any online games. I have an internet connection and im at the rank of lance cpl 2nd class but I cant play on any games?
Make sure that you NAT TYPE isn't moderate or strict if so factory reset the modem/router and if that doesn't do it, go into your modem/router via PC and set your PS3 as a DMZ host. NOT: Setting you PS3 system as a DMZ host puts your console outside the firewall.
I have a ps3 and an xbox 360...when I have my nat type on moderate then i can sign on both of them no problem but have a time trying to connect to some other of my friends. when I make my nat type open I...
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
2answers
I have a PK5000Z from Qwest, and an XBOX360, I had an issue previously with a PK5000 made by Actiontec, with NAT issues, set to moderate, it doesnt let me hear all players in a xbox live party chat, or in...
try turnig off all restrictions related. like , S.P.I. (statefull packet inspection) and try setting firewall setting for the address of the Xbox to "DMZ" . check setting of M.T.U. in router, adjust it to 1580
Good luck.
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
My nat type is open. It wont let me connected to my friends on the ps3. How can i change it to moderate and connect with them
To REDUCE NAT ON PS3 /Xbox
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Can't get NAT setting to Open for xbox 360. Won't connect to other users with open setting
The NAT is set to the actiontec modem/router so the next troubleshooting is to open the ports of the XBox ports 80, 3074, 53 TCP and 88, 3074, 53 UDP. To allow the XBox on the network using your modem/router.
Halo 3
make sure the security settings on router is WEP-Personal. I don't know what you have for internet but Dial-up, DSL, and satellite internet will not get NAT 1.
3answers
How to Open NAT?
Look for a setting like "Virtual DMZ Host". It's hard to tell for sure without knowing the make and model of your router.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
