Emerson Master
- Posted on Dec 20, 2010
Re: I have a vt1322 tv/vcr and need a code for a...
Hello
You just try with these four digit codes. These codes are for Emerson TV/VCR combos.
0227 0233 0254 0264
.... 0265 0266 0310 0325 [0039 0252]
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
NB: Switch OFF and ON your TV with its front panel power switch [NOT BY THE REMOTE HANSET] each time, before you try an other code.
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK
