cannot program remote to work on my system i have tried just about every remote and none work i just...
(More)
cannot program remote to work on my system i have tried just about every remote and none work i just want to use one remote instead of two
when i power on the tv the light flashes but there is no picture what you see in the picture is the...
(More)
when i power on the tv the light flashes but there is no picture what you see in the picture is the sun reflecting on the screen
have a green line down the left side of screen comes and goes but now its stays the tv isnt but 7...
(More)
have a green line down the left side of screen comes and goes but now its stays the tv isnt but 7 mths old
We recently moved and when we try and use the cable we only get channel 2 KET and every other...
(More)
We recently moved and when we try and use the cable we only get channel 2 KET and every other channel is a blue screen and says scanning.
32in emerson hdtv has a line in the middle of it and below the line is darker than the rest of the...
(More)
32in emerson hdtv has a line in the middle of it and below the line is darker than the rest of the tv
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
