Was the flap changed by a techician ? I have played with my 1200 and thus know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Did you purchase this unit new? If not, someone may have taken the unit apart and lost a small spring out of the antenna assembly. If you place the unit, display side down, with the antenna hinge away from you, there are two small phillips head screws on the right side. If you remove these screws, a small plastic endcap for the antenna assembly will come loose and the antenna can be removed. Where the endcap and the antenna are hinged together, there should be a small spring that puts tension on the antenna. If the spring is missing, the antenna will not remain in position.
you have poor contact with the left lid hinge and the lid switch.1st open the lid and check the 2 phillips head screws on the left side of the hinge.if they are loose tighten them and try mach.if the screws are tight,the lid switch might need to be replaced or adjusted.there will be 1 screw in each corner of the back of the console facing down.remove and flip console up,if there are no screws,take a putty knife and slide under front left and right corner of console and flip console up.the lid switch will be on left.if it is not broken out of socket,adjust hinge bar underneath switch by removing switch and bending silver bar up SLIGHTLY
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
