WHEN INSERTING A CD AND CLOSE THE COVER, IT CANNOT PLAY, AND THE DRIVE SHAFT IS KEEP ON MOVING EVEN NO CD INSERTED. AND WHEN CLOSING THE MONITOR SAID BAD DISC
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Well I fixed the problem myself by taking yhe cover off and cleaning the laser with a cue tip and alchohol very gently of course. I guess it was not reading the disc the first time it closed because some foreign object , works fine now
somthing thats worth trying is going into my computer, right click on the cdrom drive and click eject if it works that way then its software thats stopping it from ejecting, if it still dont work take a paperclip and push it in the small hole in the cdrom drive and it will pop out its only a temporary thing but it works to get the cd out..
All the Best
John
