SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
SOURCE: parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
SOURCE: error 0xc18a0206 de hp d7100
Reset the product:
SOURCE: error 5B00 de la canon mx300, como lo soluciono?
Hi you can try
Solution:
All The Best: Pineworks
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
