20 Most Recent Brother MFC-3240C All-In-One InkJet Printer Questions & Answers
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Brother... | Answered on Jun 09, 2018
Not sure what 82 code is but A2 and A1 have to do with size of paper possible original to long for size of paper in cassette
Brother... | Answered on Mar 28, 2017
There could be a posibility that you may be low on ink. The reason i say this is that you say it prints green. Green is blue and yellow. That means that your red is empty or dried out. If you are low on ink you will have a low or no ink indication and sometimes the software for the printer only has 3-5 diffrent indications.What i mean is when you see the data for your ink there are diffrent levels that it shows. Your software may not be able to diffrenciate between the colors just the status of say one color in your case it could be red.Therefore it would read 0% of ink avaliable but still be able print green. If i were you I would buy a new ink cartridge and see if you get the same results.
Brother... | Answered on Mar 27, 2017
Hi Jason, 5A is usually caused by a bad maintenance unit. The purge cam gear may be broken or too much load on the maintenance unit. Either way replacing maintenance unit should solve the problem.
Brother... | Answered on Jan 07, 2017
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Brother... | Answered on Aug 03, 2016
Brother MFC 3240C replace black ink
Brother... | Answered on Jun 30, 2016
I do not know if Windows Vista driver software for the MFC-3240C is available on CD/DVD.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista ("regular" edition) from this page.
You can download either the Full Driver & Software Package or the Add Printer Driver Wizard for Windows Vista x64 Edition from this page.
Brother... | Answered on Apr 29, 2015
hi, i normally do not work on ink jets anymore. this may be simple. find the "menu" button push "menu"then "0" then "0" it should show you a language list select your language. push "ok"..done
Brother... | Answered on Jun 07, 2014
try cleaning the primary feed rollers with 99% alcohol. make sure mahine is unplugged and the rollers are dry prior to repluggin it in.
Brother... | Answered on Mar 01, 2014
Brother MFC-3240C All-In-One InkJet Printer Logo
269 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
unable clean error 5a already reset
  • Office Equipment & Supplies
