SOURCE: Whilrpool Self Cleaning Range Door won't unlock
try this
1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
SOURCE: Whirlpool model WBP36800 range.
souds as if a monitor switch has gone bad on your self clean latch mechanism.its continuing to lock and unlock door because the switch that tells the control that the dorr is unlkocked has gone bad and as a result continues to rotate constantly
SOURCE: how to use the self cleaning feature of kenmore gas range
I NEED THE BOOK ON HOW TO USE THE OVEN ON THE STOVE RANGE
SOURCE: I was trying to use
F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Hello XilousOrtaga, thank you for your post!
I see that you would like to know how to operate the self-cleaning feature on your Frigidaire range. In order to assist you with locating a manual I would need to know your model number. You can locate the model number on the serial tag. The serial tag can be found on the frame of the bottom drawer. Once you have that information I look forward to helping you. - Matt
