When the message "Printer error has occurred 5100" is displayed, the behavior of the FINE cartridge holder is interrupted. Do you see a jammed paper or foreign material? Did you install the FINE cartridge holder properly? Please see the following for detail. If the problem persists, contact the service center for repair.
CHK PRINTER 5100 / SEE MANUAL
Cause
Action
Movement of the Holder is blocked.
Clear
the paper jam or foreign object that is preventing the Holder from
moving, then turn off the machine and turn it back on again.
There may be an obstruction that is not allowing the Holder mechanism to move.
Check
for any obstruction (paper clip, small object, etc.) and also that the
protective tape are removed from the FINE Cartridge. Check also for a
paper jam and clear the jam if necessary . Then press [Stop/Reset] and
start again.
The FINE Cartridge may be defective.
Press
[Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine )
and start again.In either case, if the error does not clear, try
unplugging the fax. Wait several minutes, then plug it back in. Also,
try replacing the FINE Cartridge with a new one.
An error requiring servicing might have occurred.
Turn
off the machine, and unplug the power cord of the machine from the
power supply. After a while, plug the power cord of the machine back in
and turn on the machine. If the same error occurs, contact the service
center.
Error code 5100 means that the movement of the fine cartidge holder is blocked. To resolve this, clear the paper jam or any foreign object that is preventing the fine cartridge holder from moving, cancel printing from your computer and then turn OFF the machine and turn it back ON again
Service Error 5100 Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response. Thanks. Have a good day.
.top3Module {
BACKGROUND-IMAGE: url(/images/Reviews/Top_3_BG_Asset.jpg); WIDTH: 310px; BACKGROUND-REPEAT: no-repeat; MARGIN-BOTTOM: 15px; HEIGHT: 361px
#RNR_rpt_div A {
COLOR: #0033cc; FONT-SIZE: 12px !important; TEXT-DECORATION: none
#RNR_rpt_div IMG {
VERTICAL-ALIGN: middle
.toptitleBest {
MARGIN-TOP: 19px; FLOAT: left; COLOR: #4f81bd; MARGIN-LEFT: 19px; FONT-SIZE: 18px; FONT-WEIGHT: bold
.wrapperDiv:hover {
CURSOR: hand
.wrapperDiv {
FLOAT: left
Service Error 5100
Thanks.
Have a good day.
It sounds like the fine cartridge movement is being restricted.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the
then turn OFF the machine and turn it back ON again. --- You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
Cause: Movement of the Cartridge Holder is blocked. Action: Clear the paper jam or foreign object that is preventing the Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
With power off, move the cartridge holders manually reseat the cartridges. Then power back on. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Service Error 5100 is Displayed
Cause
Action
Cause
Action
