Hello
If there is a voltage drop with flyback transformer connected, keep its supply point desoldered, or make a nice cut on track which supplies the FBT. That is isolate it from the main supply rail and check the voltage again. If the voltage is found normal now, desolder and take out the Flyback Drive Transistor, and check it for any leak, check it for collector to base leak. A good quality analogue multimeter is recomended for this check, beacuse digital multimeters cannot display this correctly. If it has a little leak as specified above, it will overheat after some seconds of working. Anyway replace it with same type and number.
If the fault perists, FBT should be replaced. After its replacement you should retune its focus and screen voltages for proper picture.
Hopes that you can do. Wish you sucess. Ok
If any doubts, inform Fixya. The will send me alerts.
