Sony Cyber-shot DSC-T9 Digital Camera Logo
Posted on Jun 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 61:10 code error
Thanks for the reply could you tell me how i fix this problem i know you said use w-40 liquid cleaner but is it safe to open up my camera or is that not necessary? does the liquid go somewhere else?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Jun 05, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957581
Points
33084
You have to open camera. If you dont have basic electronics knowledge, please dont open it and contact nearest Sony service shop.
Cooks Essential 6 quart pressure cooker error code - 2 upside down LL 7????
The only thing I can think of for 'LL' is 'Low Liquid'. It may also be 'eLLement' and they can't spell.
Unfortunately 'Cooks Essentials is a QVC trademark. They don't make them, they just buy from China and sell them. This page on the manual for _this_ model (you don't tell yours, 6 QT is a size, and they do lots) tells you about repair and warranty. It sounds like you have an element gone and the error is telling you in Chinese.
https://www.manualslib.com/manual/596837/Cook-S-Essentials-Cepc800.html?page=40
3answers
5answers
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution - Error Code 0xc0000185
2answers
I formatted my Sony HDR XR350 but an error E:31:00 is blinking, is there a way to solve this? thanks.
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might be able to work your way through the problem
if you need further help with this post a reply
hope this helps
2answers
Windows does not shutdown properly, asks me if i want to restart in safe mode?
It never hurts to start in safe mode. While in safe mode, some things will not be available to you. Be aware that there is a reason your computer is telling you to start in safe mode. Something happened, hardware or software related, that caused a problem. Windows allows you to start in safe mode to correct problems. Not knowing what the problem was, I might suggest starting in safe mode, then go to start, all programs, accessories, system tools, then system restore. Try to restore your computer to a few days ago when it was working properly. Then restart, and hopefully it will work.
366helpful
10answers
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
2answers
Code message
improper cartridge (destination error,life cycle error )
identification error
model error
type error
destination error
data abnormality
misc error
2answers
My Canon XL-1 has an error code and eats the tape. Before it started eating the tape it wouldn't go into record?
Can you please let me know what is the exact error code?
I will then give you some troubleshooting steps which can fix the issue.
I will be waiting for your reply.
4helpful
3answers
F61 is my problem
This fixed my unit;
remove the top cover and power it up (keep hands and other body parts clear)
check the cooling fans at the right and rear of the unit, are they turning as fast as they should be?
If not remove the fan and peel away the sticker from the center anput a drop or two of WD-40 down the hole and spin the fan until it loosens up then reassemble.
This fixed mine. Hope it fixes yours.
2answers
Error code
Try using a DVD / CD cleaner disc in the unit - this might fix the problem.
Post Back here again..
Thank you
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
