Belkin (F5D7231-4) Wireless Router Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get my belkin 37E1 to talk to the modem an embarq 660. I have a gateway computer running xp
Rakesh Warrier
Level 3:
  • Master 708 Answers
  • Posted on Oct 20, 2010
Rakesh Warrier
Master
Level 3:
Answers
708
Questions
0
Helped
209573
Points
1609
ISP : EMBARQ
Step 1 : Connect Belkin - Computer ( Computer Should go to Any one of the four the Grey colored Wired slot)
Step 2 : Make sure the embarq modem is not connected to the belkin
Step 3 : Open the Router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 4 : On The Left under LAN Setup Click Lan Settings
Step 5 : Leave the Password Blank And Click Submit
Step 6 : Change the LAN IP To 192.168.3.1
Step 7 : Click Apply Changes
Step 8 : Connect EmbarQ modem to the Yellow Slot in the Router
Step 9 : Connect Modem - Router - Computer ( Check if you Have Internet !)
Setting Up A Wireless Connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.3.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 • Computers & Internet
1helpful
Every time i hook up the wireless router to the dsl router it doesnt find the internet ( its is a embarq 660 series dsl router and i have a belkin N1 wireless router)
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
I have a Belkin mdl. f5d8236-4 v2that worked great
if ur internet service is embarq then u need to first unplug the modem from the router
because the embarq modem and belkin has the same ip address
so jus connect the computer alone to router and power on the router
then login to router setup page with 192.168.2.1 then on left side click on "LAN SETTINGS"
IT WILL ASK U FOR A PASSWORD THEN LEAVE IT BLANK AND CLICK SUBMIT
then change the lan ip to 192.168.5.1 and then click on apply changes then go ahead and click on OK
once it is done then plug ur modem to the router then unplug the powercord of router then plug it back again --- then u can have the modem and internet light to be solid --- then u can access the internet
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
1helpful
2answers
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
I HAVE A LAPTOP AND TWO REGULAR COMPUTERS.I RECEIVED A DSL MODEM FROM EMBARQ.I PURCHASED 2 USB ADAPTERS N MY SISTER GAVE ME HER WIRELESS ROUTER BECAUSE SHE NO LONGER USES IT.THE ADAPTERS AND ROUTER ARE...
Hello JAZZYBELINDA,
I read your post and wanted to know if you are able to access the internet if you connect the modem directly to one of your computers. I would like to make sure that we do not have a problem with the network. What errors are you seeing and what lights do you see on the modem and router? Please send your phone number via email or private message and I will review the network for you. Thank you for giving us the opportunity to help you.
Lamont L.
Embarq Customer Outreach
[email protected]
For additional support please visit www.embarq.com/rescueit or call 1-877-646-3282
Voice | Data | Internet | Wireless | Entertainment
4answers
Belkin wireless G router will not allow connection to internet
check for the physical cables, check if they are connected properly, if yes, try to reset the router and reconfig it
All downlods stall
try disabling windows XP firewall...
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
