The speaker has a low power output
The output of a speaker primarily depends on system design (obviously) However, perhaps you have sourced a replacement or 'upgrade' speaker for an existing system. In that case, perhaps you have an impedance mismatch. If your amplifier is designed to drive, say, an 8 ohm speaker, and you connect a speaker of 16 ohms impedance, then your sound will be softer. On the other hand, you may have connected more than one speaker to one power amplifier output. If you connected in series you add the impedances. If connect in parallel you work out the impedance using this formula:
1/Answer= 1/Speaker A impedance + 1/Speaker B impedance + 1/Speaker C impedance etc. So if you connect three speakers in parallel, each of 8 ohm impedance:
1/Answer=1/8 + 1/8 + 1/8 = 3/8
3X Answer=8
Answer = 8/3 = a little less than 3 ohms.
Reducing the load like this makes the sound louder, but risks distortion or even damage. Check your manual for amplifier tolerances. Cheers, Don.
