Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
I have the same problem. My new computer (Dell) with Vista does not recognize the camera as it relates to being able to download or view the photos. I do get an icon to "Safely Remove Casio DCS." It seems odd that it recognizes it for a disconnect but not for use. Any help?
I also have this problem with a dell running vista and would appreciate an answer or a way round it!!
