Thanks for choosing FixYa and welcome to the sight. You need to make sure your drain hose is not clogged up or your hoses are not damaged. You need to check the water pump also. It may be clogged or leaking from the pump area. Make sure the tub is not cracked or damaged, causing water to run out. Your best bet is starting the washer while you are viewing the hoses and the pump. You should be able to find the leak this way.
A friend of mine built an 18 inch high wooden base to raise his wife's washer & dryer because of her bad back, and he had no trouble with it. Speaking as a carpenter, I would make sure that your base is designed strong enough to hold the weight of both machines plus the water that will be in the washer. Use 3/4 inch plywood for the top of the base, with a 2x4 frame underneath. If it will be sitting directly on a cement floor, use treated lumber to avoid wood rot.
water can damage alot of the parts on the washer and dryer the motor would have been completly under water on both units and the control on the dryer would have gottin wet as a repair man anything can be fixed but to what cost
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Check the Vibration damper rods to be sure that... 1. They are there and mount is solid. 2. If they are broken in 1/2. 3. The plastic knuckle mounts are not missing/broken. 4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
the motor on most dryers sits approx 1 inch off of floor on bottom base plate.if you had more water than that,you have a open motor winding.aprox price for repair if u call a tech is $300.washers stand a better chance of surviving a flood,dryers very rarely do.
ck height of drain needs to be at least 30-36 inches from floor also be sure drain hose is only 6-8 inches into standpipe be sure there is a small air gap between drain hose and standpipe.. hose needs to fit loosely into standpipe or siphoning may occur
yes drain should be at least 36 inches from floorif hose outlet falls below water height in tub water will siphon out faster than it runs in try installing 1 and quarter diameter pipe into floor drain and dropping end of hose into it
