Televison & Video Logo
Posted on Oct 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sky plus remote code required to match panasonic tv
Anonymous
Level 2:
New Friend:
  • Expert 87 Answers
  • Posted on Oct 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
87
Questions
Helped
14549
Points
201
Codes 10250 10051 10055 10650 11291 11941
3answers
I am looking for the codes to run my t.v. my t.v. brand is Panasonic and the universal remote I am using is RCA RCU800MS 8-Device Universal Remote. I lost the code book and was wondering if I could get the...
The codes I have are: Code 003 for Panasonic TV
Code 054 for Panasonic TV
Code 055 for Panasonic TV
Code 062 for Panasonic TV
Code 109 for Panasonic TV
Code 130 for Panasonic TV
Code 170 for Panasonic TV
Code 214 for Panasonic TV
Code 350 for Panasonic TV
Code 351 for Panasonic TV
The codes can be looked up here: http://remotefinder.rca.com/default.aspx?site=rca for most RCA remotes. Please note these codes will work for TVs released at least 6 months before the remote was programmed.
I hope this helps.
1helpful
2answers
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
2answers
CANNOT PROGRAM RCA RCR412S REMOTE TO PANASONIC TV.(NOT A NEW TV)
try these
Code For Model RCR412S
Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV
you can find codes at http://remotefinder.rca.com/default.aspx?site=rca if you ever need codes for other.
2helpful
Code for sky plus remote please
Hi, the code is 1130, i have the same television and the code works perfectly with a rev 8 sky+ remote.
2helpful
Panasonic code
The code is 0051
on your sky remote press the TV button then
the select and Red button at the same time , hold until the led on the remote blnks twice
then press TV and enter code 0051 then press select and the remote will blink twice again to acknowledge the code
if you still have your Sky box manual all these details are in there also
im a sky engineer by the way , goodluck
2helpful
Remote control code
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Panasonic Code: 0051
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
1helpful
2answers
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
1helpful
4answers
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
1helpful
9answers
Sky+remote code for my lg tv
The cose you need is 0206
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
