Same as others, when insert the card it says card locked dunno what should i do pls help me i m going to vacation soon, want to take many great photos but the problem i had.. so sad... plz soon as possible send me advise how to fix it
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockarena.com/alcatel-ot-880-one-touch-xtra/rs13wp9/
it has a write proctect tab on the on the side of the card when its down
the card will be locked ,slide it up to remove the lock.hope this helps
pls do let me know
Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
Properly Inserted MMC to READER
Change USB port if Still Not Detecting
Try another MMC to Reader
Reinsert your MMC
Reboot your PC
Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
YOu are done...Solved.....
IS this HelpED you ...
Do RaTe mE...
you can Feel Free contact me...
Thanks for Using FixYa
Hi, Is the card locked? A small switch on the card in the lock position? If that isn't the case you may want to consider having a professional recover these photos. Once I have more information I can assist you further. Thank you, Lee
On side of The SD card there is a little lever that slides up and down this is the protection lock. PUSH it all the way to the top. Sometimes when inserting it gets caught and will move just enough to have the camera consider it locked. So be careful when inserting it.
If this does not fix it try another SD card or reformat it.
You need a memory card reader..u cant directly insert a card into your CPU..If you got a latest HP CPU..It has a card reader port...If urs is a year old or more then you got to buy a card reader...
please rate my suggestion...
....help
