20 Most Recent
Sony Cybershot DSC-S950 Digital Camera Questions & Answers
Screen says reinsert the memory stick but memory
get the card out ..be sure it is no locked...and it is inserted in the proper way ..if it still says the same after this ..verify the card into a card reader to see if it is ok ..cause if it is damaged the camera will not see it .....If you just replaced this card and it is new ..be sure you format it in Fat 32 before using (can be done in computer or in the camera ) ..also be sure that the camera is supporting the size of the card if it is a new one and never used before in this camera ..
Sony digital camera recovery
No, probably not. If you've taken more photos since then, then DEFINITELY not.
When they're deleted from the camera, they're deleted forever.
Pc transfer pics
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Flash not working
Can be for severe; reasons.
1. There is enough light.
2. You can force the flash, with the mode switch to Flash forced on, Slow synchro and Flash forced off. Try flash forced on.
3. The battery is not fully charged. When there is not enough power in the battery, the flash can't be charged enough to fire. But if the camera tries to charge the flash, a symbol with a lightening arrow and a dot is displayed. So if you see these symbols, could be you need better batteries. Try charging the battery.
4. the flash is really defect. Could happen too, but first check if everything from 1 to 3 is as it should be. only than you have to visit the repair shop or Sony if it is still in warranty.
FLASH NOT WORKING, ALL SETTINGS SHOWING GOOD
You may try to reset to factory settings. you may try to restore Locate the RESET button on the camera.Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds and then release.
My sony cybershot DSC-S950 effected
use asoftech photo recovery program to scan your usb and then recover your files.
http://www.asoftech.com/apr/This software scans all storage space on usb and then join pieces together to recover photos. So even virus affected your file table, and put virus to boot sector, the program can still be used to recover your photos.You need to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Ma camera is not working
You can re-enalbe the flash of this camera by pressing on the lightning button repeatedly until flash is enabled
How can I transfer pics from sony cybershot
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
