Acer Aspire M3200 19" 2.5GHz Athlon X2 Dual-Cor 320GB 19" LCD  PC Notebook Logo
Posted on Oct 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CD will not eject - Acer Aspire M3200 19" 2.5GHz Athlon X2 Dual-Cor 320GB 19" LCD PC Notebook
Anonymous
Level 3:
Guru:
  • Acer Master 1,705 Answers
  • Posted on Oct 08, 2010
Anonymous
Acer Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402842
Points
5112
Look closely at the front bezel of the disk drawer. You should see a small hole.
Straighten out a paper clip and push it in the hole, quite firmly.
This is the standard fail safe release mechanism.
What key to use to eject a CD on a Logitech using Mac
How to eject disc from Mac using keyboard?
Hold down F12 as you restart the computer until the CD ejects itself. Hold down the left mouse button as you restart the computer until the CD ejects itself.3 Mar 2012
How to Eject a CD From Your Mac Using a PC Keyboard or USB ...
www.iclarified.com/.../how-to-eject-a-cd-from-your-mac-using-a-pc-keyboard-or-usb-... Search for: How to eject disc from Mac using keyboard?
What key to use to eject CD on Logitech using Mac Google Search
tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 • Computers & Internet
I put a cd in my cd player and it will not eject
start up holding down eject button,
go to file menu and hit eject cd,
good way to start,
2answers
Instructions on how to eject a cd from vostro 1510 ? [email protected]
You can eject a CD in two ways!
1 Simply pressing the button on the right edge of CD drive and drive opens by sliding out
2. Clicking on my computer which shows all the drives C: D: E: etc. C: is hard drive so can not be ejected. Right click on the D or E where ever the CD is and choose eject! That will open the CD drive!
2helpful
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
3answers
JVC won't eject my CD!
Turn radio off Push and hold the eject button Turn radio on while holding the eject button.
This is the force eject sequence
Cd player will not eject holds 6 cd 2001 ls licoln says cd error
This happens to me as well, usually if you press and hold the eject button all of the cd's will be ejected. A couple of times I had to use another cd to kind of slide underneath the stuck cd to assist with it ejecting while I pressed the eject button.
1helpful
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
4helpful
3answers
Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
