Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Posted on Oct 08, 2010
My canon eos1000d camera does not click picture. when i press the button, it focuses the picture as usual, but does not click the photo. any solutions?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
97
Points
I have the same trouble... somenoe said to that might be problem with lens, he said thah i couil try with another lens, but i've got just 18-55... try, to take out memoy card, and take off lens...
Hy guys. I am having a problem with my Canon S5 IS. Before pressing the trigger button the picture I see on the display looks ok (bright and sharp) but after taking the picture (or even when pressing...
This is a very odd problem. I wonder if you've got the depth of field preview button activated. As you look at the camera from the front there is a button on the left below where the lens meets the body roughly at 7 'o'clock That is usually the the DOF preview button. Try a little fiddle with that.
Pictures are blurry unless I push the picture switch down very slow
Good day,
I have heard a lot of complaints about people taking Blurry Photos.
There are a few possibilities for it and a few easy fixes.
The first possibility I would identify is a dirty lens. To fix this simply take a clean microfiber cloth and gently clean the lens until there are no smudges visible.
The other possibility I would identify is that the pictures are out of focus.
This problem can be caused by a dirty lens or because the object or person was not focused on. To ensure focus on your photos, line up your shot and wait for the camera to focus by pressing the shutter button half way down. When focused press the shutter button in all the way and hold the camera still until the photo appears on the screen. By doing this you will eliminate any motion that might mess up your shot.
Please let me know if these tips work for you!
Regards
Cannon EOS500D, taking a picture in creative modes I have to press the shutter button twice to take a picture.(not counting the half pressing of the shutter button. the second pressing of the shutter...
Hi kevinmullen8 - was this ever resolved? My mum was mucking around with my camera (eos1000d) and I have the exact same problem (press shutter twice in creative mode). Factory reset was of no assistance.
Please help!!!
Bleeping
Do you have your camera set for continuous focus tracking?
2answers
I press the button to take a picture. You get the beep beep, but it will not click and take the photo
Clean camera lens, let it focus on any item after that press half finally fully press the shutter.
I have just purchased Canon Powershot A480
I think the "busy" part can be put down to the camera performing a function or recharging the flash. The red icon I THINK shows that the camera is focussing.
With the last model it worked so that you could half press the button to focus on something (eg a fast moving pet) and then once your pet stopped moving your could fully press the button to take a photo and the focus distance would remain the same.
2answers
When take photos it looks in focus through the viewfinder, but the pictures come out slightly out of focus
I'm not sure what camera you are using. But I believe you are taking pictures like the old Kodak Instamatic which you just literally point and shoot. Even then people took blurred pictures. There are 2 reasons I can guess. First is you are pressing the shutter button too fast. When you press the shutter, it should be like squeezing the trigger of a gun. You SQUEEZE slowly. Not press the button and let go. After you hear the camera has done all the sound it wants to make that means you picture is being recorded. And hopefully it will be clear. If it still isn't then it means your camera take a little bit longer to focus on the subject. That's what happened to my wife. She thinks she can point and shoot and that's it. You need to camera a few seconds to focus. I know the Casio's have a little beeping sound that tells you it has focused and is ready to shoot. My Konica Minolta does the same but I see a box on the screen (I took the sound out). You need to listen for that tone that tells you you camera has focused on a spot and is ready to shoot. In order for the camera to do this you need to press the shutter only half way. When you hear the tone then slowly press all the way and don't move till all the clicks are done. That's usually 0.5-1.5seconds only. Hope this helps.
The focus on my cannon powershot A540
Do you focus and then push the shutter button half way down to lock in that focus? Then all the way to take the picture?
Do you support the camera on a tripod or kneel down and support your arms on one knee or lean against some object to keep the camera steady> You can even press your arms tightly against your body before you focus and shoot. And be sure to press the shutter button very gently when you shoot so the camera will not shake or move.
Do you have the camera on the right mode for the photo you are attempting to take? Such as night/macro/action/ etc. Try taking photos on just the automatic mode to see if you can get focused shots. Make absolutely sure your camera is not in Macro mode ( a picture of a little flower on the screen) unless you are doing extreme closeup shooting.
Go to your menu>then setting> then set your camera back to default settings if you can. Or if you are unsure how the camera is set. If you do not have your manual you can go to the Canon website at www.canon.com and click on support or downloads and find the manual for your camera and download it. That may give you the answer you need as well.
Please get back to me if you do not have any luck and send along more info such as camera age.
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
2answers
Camera
PRESS AND HOLD DOWN THAT BUTTON TILL IT TAKE PICTURES or PRESS IT FOR 2sec AND leave
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
