20 Most Recent Canon PowerShot A480 Digital Camera Questions & Answers
on the mother board, a fuse is laying, it passes the battery power,test it, if it is open just shot it with a very thin wire.
Canon PowerShot... | Answered on Sep 10, 2017
not able to get opendand the sensors of the lens unit not able to conform the position of the lens,is due to the damage of the gears/mechanism of the lens fuction,so get it serviced/replace lens unit
Canon PowerShot... | Answered on Sep 01, 2016
Google = EaseUS Data Recovery Wizard Free and it should recover most if not all lost photos? I lost several photos on some SD cards and i tried this free program and it worked perfect. There's other free programs like this one but this particular one worked fine for me. It is simple and fast, give it a try.
Canon PowerShot... | Answered on Feb 14, 2015
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Canon PowerShot... | Answered on Feb 12, 2015
When you say that the camera keeps scrolling when you view a picture do mean it scrolls to the next picture ? If so, you probably have it set to Slideshow which will automatically scroll to the next picture. Go to the main menu and look for Slideshow, if it is on turn it off.
Apparently not. Do you have trouble with the date or time?
Canon PowerShot... | Answered on Jul 11, 2014
You need a computer. You need to transfer the photos from the camera to the PC via the Interface Cable IFC-400PCU and the power shot software that came on the cd. You may be able to get a card reader device and plug the memory card from the camera in the correct memory card slot of the card reader and then browse the photos via the upload photos browse in facebook on the computer.
http://www.manualowl.com/m/Canon/A480/Manual/41542
http://www.canon.co.uk/Support/Consumer_Products/products/cameras/Digital_Compact/Powershot_A_series/PowerShot_A480.aspx
Canon PowerShot... | Answered on Jun 23, 2014
Hi!
Tutulungan ka namin maayos ang sira ng phone mo.
Paki explain kung anung klase ng sira, pyesa ba o merong error code na lumalabas sa display.
Para mabilis ka namin matulungan
Add ka lang ng comment dito.
Salamat.
Canon PowerShot... | Answered on May 23, 2014
Take out your SD card and check to see that the switch is in the "unlocked" position.
Canon PowerShot... | Answered on May 05, 2014
Take out your SD card, turn it over and make sure the switch on the back is not in the "locked" position. Sometimes the switch position can be changed with handled.
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Canon PowerShot... | Answered on Mar 03, 2014
Please have the question with clarity as we at Fixya can help out.
If youment flash is not charging, then check if the flash is in auto or manual mode. change as required in the menu.
If not flashing then the faultis within the camera and must be looked into, can be flash lamp, the capacitor or the driver./trigger circuit.
Canon PowerShot... | Answered on Nov 14, 2013
293 questions posted
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
canon powershot a480 isn 39 t
  • Cameras
