Hi Thanks for using FixYa. To resolve this you will have to reset the console. Do this
by closing the door and press these buttons in sequence... -heated
dry -high
temp wash -heated
dry If still its not resolved then press and hold the AIR
DRY button for 15seconds to reset the control. Please accept the solution if
the issue is resolved or post a comment for further assistance. Rylee
-high temp wash
Thanks
Thanks Rylee, We don't have buttons labeled that way. Ours are, on the left in order from the left, Pots Pans, Normal Wash, Water Miser, China Wash, Quick Wash, Quick Rinse. Above the last two it says No Dry. In the middle there are three buttons, Water Heat, Sani Rinse, No Heat Dry. The last buttons on the right Delay Stat, Start, Cancel Drain.
As you can see there are no buttons labeled as you indicate. Hopeful you have a combination that will reset this. Thanks
Thanks Rylee, that did not work either. No change!
Rylee,
Something worked. I had been away from the washer for about 2 hours. When I went to try your last suggestion the display had changed. I did you last suggestion but don't think I needed to. Thanks a bunch. For now our washer is back in service.
Rylee got us 'back on the road' so to speak. Thanks
Spoke too soon. It started then stopped with 18 in the display
