the printhead it is attached at each cartridge, so, there are two options: a) cartridge damageds or b) bad read cartridge contacts. Do this, take out the cartridges, check if the contacts are clean and dry, then be sure to fix well again in the printer, if an error message appears, push the cancel button by 6 seconds, this deactivate the ink level sensor.If the error stay, 6 seconds 1 more time, if not works, I think that one or both cartridges are damaged, try with a new pair.
this is a common problem when using refilled cartridges.
You can either go into Control Panel --> Printers and Faxes
Right click on the printer and select properties, then look for a maintenance or color section
How I can fix the U051 problem with my conno : MP470 printer ? It says the print head is not installed. Install the print head. Where is the it , and how I can fix it?
please e-mail to [email protected]
No drivers are available for the printer for Windows ME. It may be time to upgrade your computer if you want to make use of newer printers and hardware.
same problem. brand new printer.
same problem. just opened the printer today.
Same problem too :/
used recycled cartridges. printed 5 documents, then it said ink ran out when there was almost a full load in there. error U051.
