I have a Konica Minolta camera Dimage Z3 that was given to me so I dont have the manual I have the box and cords to it .The promblem is the screen is white it won't let you take pitures you can hear it taking the pics and it will flash but you can't see anything but a white screen. Does anyone know about this type of camera? Thanks so much!
SOURCE: camera screen is white when turned on
the problem is not with the screen as you can see other photos and menu
it may be with the image sensor or lens
this would definitely need a repair
SOURCE: white screen (no picture) when camera is turned on.
It is probably an issue with the LCD display panel of your camera. It may be just a LCD connector cable coming loose or the panel itself is damaged(Kodak cameras are notorious for this issue). Fortunately it is a relatively inexpensive repair. If the camera is under warranty make use of it to get it replaced for free. Note that the warranty is void if there has been a water lodge or if you take it apart yourself.
