Sony Alpha DSLR-A300  Digital Camera Logo
Posted on Jul 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
Anonymous
Level 2:
  • Expert 489 Answers
  • Posted on Jul 25, 2011
Anonymous
Expert
Level 2:
Answers
489
Questions
Helped
139321
Points
960
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
  • Rhonda Dusak Jan 31, 2014
    the screen stays white and wont show anything cant playback or see anything live
2helpful
LCD Screen
Your camera is working exactly as SLRs have worked for the first half-century since their invention. You frame the picture through the viewfinder then take the shot. The display is for menu settings and reviewing pictures after they've been taken. Newer DSLRs will let you use the display for picture-taking (and take videos) but the A200 belongs to the previous generation.
Sony dslr-a330 live view not working correctly
I can't help you, but perhaps ifixit dot com com. There you find manuals and videos about how to repair lots of electronics. They even can deliver special tools and spare parts. The manuals and videos are free. Descriptions from too many cameras to be sure yours is there too. The dot com, I use to avoid filling in these nasty puzzles. you know replace the dot with a .
Camera error appears after pressing button
If you have a camera error, or a system error, you should switch of the camera, remove the battery and reinsert the battery, before switching it on again. If this happens frequently you should contact a authorised Sony service centre. While you have the battery out, you could check if the contacts are clean, free and shiny. (on battery and in the camera)
Shooting a wedding on Saturday and wanted to know if it is possible to turn off the sound on my alpha 300
hi amynguyen21,
You may try this steps to turn off the sound on the DSLR-A300...
1. Press the Menu button, it is the top button on the left of your LCD screen. then go to SETUP 2 (hint: SETUP 2 is symbpolized by a wrench with the numeral number 2) then select Audio Signals then from the options select the desired sound settings.
1helpful
Sony Alpha DSLR-A300 LCD screen does not power up as if there is no power going to the screen. the camera takes fine pictures. to view the pictures, you will have to plug the camera into a computer.
It is for sure that the LCD display is not working. Hence you need to probe into the camera to confirm but attempt only if equipped with the right tools and some experience , becasue as of now your camera can shoot good pictures and you must not end up tampering to damage the camera.
If not get help from a friend or the nearest sony service centre, get estimate and replace accordinly. You will be lucky if the fault is a power link failure, if the display needs replacement then the cost is the issue, try if you can get a salvaged display unit.
hope this helps. Good day
Sony a350 lcd consumer replacable?
I am sorry to hear regarding this Problem. If you are good at Repairing electronics, you could Fix that. But, the Main Problem is LCD Screen. Sony Does not allow the Screen to be Sold Separately and they would charge around $125 - $150 to get the Screen Fixed.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1helpful
Sony a100 broken screen
That's not too bad of a problem to live with if you don't end up fixing it. You probably know this already but what you see through the viewfinder is exactly what shows up on the lcd screen after you take a picture.
Have you:
*Tested the camera to see if any of the options and/or buttons work?
*Taken any pictures with it and uploaded them to your computer?
Do you have a user's manual that can help you navigate through the options? If not, feel free to send me a message.
As far as repairing the screen, familiarize yourself with other Sony screens if you can't find anything on the A100. Check out http://www.youtube.com/watch?v=UR8mqXd4Jrw
2helpful
2answers
No viewing display on LCD screen
Push the evf/lcd button and it should work.
LCD - Focus
DSLR camera was not made to be used as a point and shoot camera and you cant preview the shot before taking a picture. You are to use the eye piece to focus right. Also before taking a picture, push the exposure button just a little to let the camera focus right.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
