Mitel Superset 4025 Corded Phone (mitsup4025) Logo
Posted on May 21, 2008
Message Display A common source of frustration in our office is that our display says that we have '1 message' regardless of whether we have one new voicemail or 25 new voice mails! Is there any way to change the display so that it will show us exactly how many messages there are? Thanks!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
254
Points
Your voice mail is probably set to send notification for the first message only. No matter how many are in there, it will only tell you once. You may be able to change the notification type, depending on your voice mail.
How do I clear the "Replace Waste Toner Box" Message from the display - new WT220CL installed in a Brother HL3140CW?
To clear the message 'Replace WT Box' from the LCD display, power off the printer using the power switch on the right side of the printer. Wait 5 seconds and then power the printer back on. If the printer continues to display the message 'Replace WT box', the waste toner box is full and needs to be replaced.
How to remove error samsung scx-3405f install toner cartridge
Try these steps:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Let me know if it doesn't work as there is another possible solution.
When connecting tv to pc i'm getting an error message 'no signal input detected'
Did you click on the source button? Also you have to go to your desktop right click with the mouse thern click on properties you will go to your display settings you should see 2 display squares 1 & 2. now you can clone or extend. Another thing it would help to let us know you OS ie win xp or 7 or whatever. Whether you've got Nvidia or ATI or onboard Graphics. So I'm just giving you the basic info..Hope that helps Merry Xmas.
Error code 1 - reconfig message
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
2answers
Display shows "1 new/1 saved" yet mailbox empty.
The message left on your phone was probably left by someone internal, meaning they called your phone and when you did not answer, they hit their message key which turns on your message lamp and display. If you press your message key and it rings someone in the office then they are the one that left the message and they have to answer your call. You can usually cancel the lamp/message on your phone by pressing " Intercom ( your extension button ) " # 4 0 9 and then hang up. You can have up to four ( 4 ) messages on the phone so it may take putting in the code a couple of times to clear the display.
1helpful
Message waiting light won't turn off
Have u ckecked whether the message box is full?
Try clearing all the messages from the setup menu
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
3helpful
2answers
Can't install the solution disk
Change your compuetr's display resolution to a better performance. Click with the right mouse button on your computer screen. - The Display properties window will open - Click with the left button on the Setting tab. - Change screen resultion as required - Press "apply" Check whether the new setting solve your problem. Good luck!
Top Mitel Lands Phones Experts
k24674
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
