Hello i have tried to turn the blak drainer aT THE bottom of the washer but wont open does it only open part way around or should it turn all way round.
I had similar on an indesit 123 suspect something in drain. remove hose from pump end remove any blockage last time i found 45p in the body of the pump ,good luck
Remove ALL media DVD,DC,USB, Unplug, remove battery, plug in, reboot to restore/recovery OR safe mode. Post results. Have you done ANY updates? Any damage? Fan spins? LED's Blink? White cursor in the top left of black screen?
check all the pipes comming from the drum to the pump take the back off they will be at the bottom of the m/c being held in place by thick plastic what look like cable tyies socks have a habbit of getting in there and blocking up the drainer pipes hope this helps
Open up All printers and faxes by right clicking the printer icon in the system tray.On the maintenence tab check your black ink.Check to se if the tape is stil on the carftridge. If it is remove it. Printer should print black ink once the tape is removed.If it is removed. Try changing your black ink for a new one. Also sometimes your ink may not be compatible. Make sure you use compatible ink
The drainer is very easy to remove...
Just use a screw driver or the jamm wrench to un hook the disposer from the drain by turning the ring that connects it to the drain.
Tehn loosen the three screws that hold the drain onto the sink bottom and take off the snap ring and the drain will pop right out...
hello. i can assist you. when a washer won't agitate, one of several expensive repairs are in order. If your washer is more than 5 years old I recommend replacing as opposed to repairing. That said if you want more information on what might be wrong get back.
Since you are looking inside, try this. Trace the wires that come from the power switch back to the Motherboard. The wires from the switch will connect to two pins on the motherboard. Carefully jump those two pins with a screwdriver and the machine should turn on. I would suggest doing this with all drives and cards unplugged first.
pink wire should be ignition, and black one is ground, black one should be comin out of the external amp and the pink one should be on the side of the deck i believe, also yellow one should be next to the black one thats your 12v constant, yellow pink and black should be all ya need to get it to turn on atleast
does the washer have paddles on the inside of the drum if it doesnt then try putting alittle less clothing if there is too much clothing then the items tenned to get pushed together and tangle themselves up which means together they are to heavy to spin
