D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
Posted on Sep 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Anonymous
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Sep 15, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
91
Questions
Helped
23642
Points
220
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
2answers
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
D-Link DIR-615 Wireless Router not connecting with HP Network Printer
Please use the utility disc that comes with your printer. It will help you to connect your printer to your wifi router.
Or please check if you type the correct SSID of your wifi (Wifi Name). SSID are case sensitive.
1helpful
2answers
2answers
I am connected to a DIR 615, it says I have wireless connection but it won't connect wireless, if I connect a cable it is fine??
Hi mike63771,
All you need to do is to set it up properly. Make sure that the router is connected to the computer using an ethernet cable so that the computer will be able to communicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Go to the Wireless Settings Page then check the SSID or Network Name and the Network Key or Passphrase. Now try to connect to your computer. Click on Start then click on Connect To. Select your Network Name then if it ask you to enter a password enter the Network Key. You can personalize the network key on the router settings page.
Rate me if this helps so i can help other.
Thanks for using Fixya.
My wireless network crashed,how do i get it back.i have a dlink DIR.615. thanks.
If the Wired Connection from the router is still working then login to the routers Interface and recreate the Wireless Network with a SSID name and Wireless Security password(WPA Personal) Recommended as its more sure.
My D-Link DIR-615 seems to drop the wireless connection often but the wired works fine. Any fix
1. Please check your D - Link router should be not placed in corner.
2. Please check your D - Link router is placed on some open place.
3. if your notbook and router is visibale to each other then you can get better wireless connection.
1helpful
No wireless on Time-Warner cable. LAN works fine
Yes, from what I understand you need a special router to go wireless with timewarner, just another way coporate America dicks the regular guy.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
