Cell Phones Logo
Anonymous Posted on Sep 15, 2010
My incoming call's does not show name of caller, only displays call. i have a nokia 6131 I have reset factory settings but still does not display name. thankyou jennifer
  • Anonymous Sep 15, 2010
    Have been through the settings does not help
rwc120
Level 3:
  • Master 341 Answers
  • Posted on Sep 15, 2010
rwc120
Master
Level 3:
Answers
341
Questions
0
Helped
106554
Points
1095
my incoming call's does not - icon_text.gifHow do I set my Nokia device so that when I receive a call my device says the caller's name? To have your Nokia device say that name of the caller on an incoming call, please do the following: Press the Menu key Settings This info taken directly from Nokias website
How can I get my panasonic KX-TG8855SK to show caller name?
How do you get caller ID on your home phone?
Incoming calls: How to display and switch off caller ID
  1. To display the caller's identity on your phone's call screen, dial *234#.
  2. To check whether your phone is set to display the caller's identity, dial *#234#.
  3. To hide the caller's identity on your phone's call screen, dial #234#.
  4. Note:
Incoming caller name and number is not showing
Hi, My Nokia 130 phone does not display number for incoming calls. It shows "private number" for all the incoming numbers. I tried moving contacts from SIM to phone, removed duplicate entries. Even restored the factory settings twice. But still it does not help. I will be grateful for any help in this regard.
Nokia e7 caller display not working
is the caller number display or nothing at all?
if the caller number is displayed,check you contact,might have enter same caller number even if different names.
if not,try to reset your phone,go to settings and restore factory default or just type *#7780# for soft reset (nothing will be erase and back to default) or *#7370# for fukk format or hard reset (this will erase all of your data stored,be sure to back up important data defore proceeding)
2answers
Nokia E66 Incoming name or number of callers not
It's because the caller using voip (ie Skype or similar with hidden id)
Display caller name and number for NokiaE90
dear ,your setting has been changed just you the following code and enjoy.
*#7780#
restore factory setting then phone will be restart
i hope this problem solved
2helpful
2answers
Incoming Calls From Contacts Show Up as Unknown Caller
okay follow me brothe am gonna help u!!
1/set ur phone on his factory defaults
2/try to copy the contacts from ur SIM card to ur phone memory so it will be able to recongnize the numbers in his memory!!
i hope that would be helpfull
4helpful
5answers
Wont display # for caller id just displays name
my caller id wil not show names or numbers just incoming calls
NOKIA 6131 PROBLEM
Hi go to ur mobiles setting and select full fectory default its security code is 12345. thanks keep voting.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
