SOURCE: Power Generator
You have a brushless generator and you've already checked the capacitor that does the voltage regulation (wiring is fine).
The next thing to look at are the diodes, movs, and wires in the rotor.
Carl
SOURCE: NEED WIRING INSTRUCTION FOR CAPACITOR FOR
On top of the capacitor you will find the terminals marked. One will say C, or Com. The others will be marked fan and herm. There will be a hot wire going to C. Usually this comes of the top of the contactor and is red. Find the wire that runs to the compressor. It will likely be yellow. This will hook to the Herm. Next find the fan wire (probably brown) it will hook to the fan. Hope this helps.
SOURCE: I am putting a new capacitor on a stay rite 1 1/2
You have three wires....
one of the wires goes to the start windings of the motor (this wire is usually yellow) and goes to one side of the cap.
The other two wires are the power in and the wire to the common winding ( usually this is a black wire) of the motor....
they go to the other side of the cap....you will have one prong on the cap empty on the side with the start wire...
heatman101
if there is only two terminals then it does not matter which wire goes where
SOURCE: order capacitors for Hunter fanscapacitors Where
Call Hunter parts @ 1-888-830-1326 w/fan model #
