When I first turn it on,it turns on and the words RCA appear,nothing wrong,but then it turns off and on etc. until i take out the battery,any suggestions?
Mine's the same way. It just started yesturday and I've had mine for over a year.
I don't think it's the hold button, because mine was doing it and the hold button was off.Mine's the same way. It just started yesturday and I've had mine for over a year.
You can't post conmments that contain an email address.
There are two ways to solving this problem
1 keep taking the battery in and out until player functions
2 try different batteries i recomend energizers (they seem to work the best)
Is this a tablet? You can do a factory reset by holding the power and volume down or up bottons at the same time for a few seconds. At first it will t Reset keep holding the bottons a few more seconds until the factory reset option comes up. It will erase everything and give a fresh start.
Sorry no relay , bad instrument cluster . The gauges get there info from the PCM - engine computer over the SPI serial data bus ! Google SPI or Chrysler CCD data bus !
i have exactly the same problem. i have tried tapping it gently, hitting it hard, changing the battery etc. nothing seemed to work. i guess the best bet is to take it to a service centre
You have bad switches inside the tv. When a switch gets stuck nothing else will work including the remote. In other words, the microprocessor can take only one command at a time. Replace all the switches at one time to avoid trouble later.
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections..your current “work around” is your only solution.
