yes there is a red light a small one on the front of the tv. when i try to turn it on the light will blink each time i press the on and off button,it is suppose to turn green when the set turns on but doesn't.yes there is a red light a small one on the front of the tv. when i try to turn it on the light will blink each time i press the on and off button,it is suppose to turn green when the set turns on but doesn't.
You can't post conmments that contain an email address.
I had the same problem with my ILO tv, I found a code for Funai- manufactured by the same company. Unfortunatly I don't know the codes anymore, but I hope it helps.
This is a familiar problem with Ilo, ours came earlier when there was still an Ilo to call and the set was only 6 weeks old.
The problem is probably with the circuit also used for the IR remote; the set-top buttons and the remote both are processed through the same defective circuit.
Jimmy's parts may have what you need to get control over your set:
Jimmy's
They seem to have an unusual quantity of Ilo parts and may have bought the leftovers out of bankruptcy.
Good luck - just remember WalMart when you start laying out cash for their junk.
The GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
Turn the tv on. Set the remote for a code. click the off button, then the chanel UP button about once a second till the tv turns off. Then click the # to set the code. This should work.
Old Man Cleat;
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
I understand Ilo's are made by Tatung. You may try 0055 or 0003. I haven't confirmed this, but it's worth a try.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
Do the controls on the tv itself work or just the remote? If it's the remote mabey it's defective. I would look on the Ilo site and see if they recommend a universal remote for their models ( or just getting yours replaced ). If the problem is within the tv, I'd look into the warranty. Sorry if this wasn't any help.
